R56 2012 MCS Stuttering/Exhaust Pop during over boost
I need some help. This just started happening tonight. After my car was completely warmed up running at 105 degree Celsius, when I completely mash my foot down and go into over boost... at around 3500-4000 and over I start getting many exhaust pops and during these pops my power is dropping severely. I'm concerned but hoping it's something as simple as spark plugs maybe? Car has almost 50k on it and I don't believe they've been changed yet... but I fear it's something massive like the turbo or intake manifold causing the issue, or maybe even carbon build up... which my car would then turn into a lawn ornament as I have zero dollars for that.!
There is no limp mode or CEL of any kind... just exhaust pops and burbles as if I let off the gas, except I'm full on the gas... and each pop and burble make the acceleration stop.
I noticed a slight stutter during idle the other morning, but it was -12 degrees ferenheit so I chalked it up to cold weather. Today however was much warmer, and the idle is fine today, only the high rpm stutter/pops... for mods I have an Invidia Q300 catback & the previous own had a stage 1 manic tune done on it.
Initial thoughts are check plugs and coils, then depending on mileage carbon buildup. Worst case, high pressure fuel pump. Mine is doing almost exactly the same thing with the same previous symptoms and depending on your build date you might have the same fuel pump that is prone to failure.
If those are the original plugs and you've not carbon cleaned before... holy cow, it'll feel like a totally different car afterwards.
I'm guessing the CEL doesn't stay on for you? If it does, you should pull the code.
The more I drive my car with this issue I'm almost certain it's an issue with plugs or coils... Because idle is 100% fine before & after warmup. Even while driving normally on the highway it's fine. It's only occurring when I absolutely mat it and over boost comes on.
I had a bad misfire when I went Stage 1 initially because of a bad coil pack. I let it go for like 3 or 4 days and eventually it just got worse and worse because the coil was shorting and melting itself on the inside. I hobbled myself over to a BMW dealership and bought a set of new coil packs and it fixed it right away.
Though mine just misfired, no exhaust pops or bangs. More of a stuttering if I mashed my foot down.
Yes, you are correct. It goes off as soon as I re-start. Are you suggesting it could be my HPFP causing the temporary CEL?
Since it's only during full throttle I'd assume the spark isn't sparking as needed for the amount of fuel being injected, hence the exhaust pops from unburnt fuel hitting the exhaust (sort of like sport mode does). Now whether that's the plug not sparking correctly because it's bad or because a coil isn't functioning properly, I couldn't say. What leads me to believe it isn't the HPFP right off the bat is the fact that you're getting unburnt fuel, which I'd think would mean the fuel flow is adequate.
So I wasted my money and started with changing my coils 2 weeks ago which didn't change anything. The reason why was because spark plugs were change 30K miles ago. Today I swapped out my plugs and problem SOLVED!!!!! Smooth all the way to the limiter. Hopefully this is also your solution.
Just purchased this ignition kit from ECS tuning this morning, expedited the shipping so I should have it either tomorrow or Monday morning! Will let you guys know how it turns out once replaced!
https://www.ecstuning.com/Mini-2012-...ion/ES2893833/
Update:
So I had already ordered parts for ECS Turning on Friday. Saturday I go to work as usual, try to leave work and BOOM limp mode right away... apparently the misfire had become violent enough for my ECU to do something about it as the engine light was flashing on the speedo as well...
So seeing as I need my car 24/7 for my job, I tried to find some plugs and coils at some local vendors with no luck. I finally had to bite the bullet and purchase 4 coils and 4 plugs from MINI dealership for almost $500...
Good news though! All 4 plugs/coils replaced and car is running better than ever! Problem solved.
Same issue
I am experiencing this exact issue. It's been happening intermittently when I get on it full on at highway speeds. Until today, it never threw a CEL but this evening on the highway it threw a CEL and the engine must've gone into limp mode because power was way down. Pulled off to nearest exit and read the codes. 2 cylinders experienced a misfire. Thanks for all of your helpful info on here. I will try new spark plugs first and go from there! I'm hopeful that will solve my problem! I will post an update as to what my results are soon.
update:
I changed my plugs with Genuine Beru OEM plugs and this solved my problem.
I would recommend starting there for your issue because from what you described my problem was exactly the same as what you seem to be experiencing. The Gap on my old plugs was shot. Which would stand to reason why when getting on it and the boost increases the plugs weren't able to do the job.
update:
minibdb
12-06-2018 02:30 PM
