R56 2011 MINI CooperS
#26
That is seriously strange. This will be a tough one to diagnose unfortunately. I'm thinking maybe a pulley, but it only happening one time is strange.
The wheel well panel rivets are HERE.
That's what I don't understand either. Will do it the the first drive of the day but never again until the next day. Thank you for the link for the panel screws. Do you know what screw I need for the underbody that attaches the fabric paneling to the underside of the car.. The Passanger has a silver screw and the left side is missing the screw which allows the wheel well fabric to remain loose..
#27
Did you check the brakes and the lip on the rotor ?
I can help you with the liners I had them out.
http://www.realoem.com/bmw/enUS/show...diagId=51_6296
There is a clip 07146981767 and screw that's already on the under panel. I have done the GP2 underbody belly pan conversion before.
Screw from underbody splash guard: 07147177492
https://www.ecstuning.com/Search/SiteSearch/07147177492/
On the driver side there is no use for the inner hole.
Do you have a pic of that area?
#28
#29
888.280.7799 | 6am - 5pm PST
#30
#31
Thanks, yea , there is nothing there to hold it. That's what it comes like from the factory. So nothing is needed.
#32
#33
Ah I see. The front doesn't have anything but the C-Clip HERE. The back of the wheel liner, closer to the door has those 2 that hold it down in my image above. Look at this diagram HERE. It'll help you. If the liner is in good shape and it's not cracked/torn or worn you shouldn't need to replace it. From that image it looks to be fine. Otherwise, if you do we have it HERE.
#34
Let us know how it goes.
#35
Sounds good. Make sure they check out that pan and see what they recommend as far as replacement. Good luck!
#36
I'm hoping the dealer will replace it while they have it- at their cost. Or a discount. Doesn't hurt to try. I also purchased an extended warranty today, just in case any new issues arise in the future.
#37
Sounds good. If they don't and you need any help with anything just let me know.
#38
UPDATE: Ok guys, MINI Cooper is replacing the trans pan and fixing an oil leak at their cost. The noise I was hearing was in fact normal and part of the turbo system. Air filter enclosure was loose caused a slight pitch when breathing air. So I'm very pleased with the outcome. I get my MiNI back tomorrow. They have me in a loaner 2016 mini hardtop and I do not like it as much as my 2011. It's to smooth and quiet.. Also it doesn't feel like it has as much get-up-and-go as mine.. Did they change motors or something?
#39
#40
Very happy to hear this. Glad all is well and you'll be enjoying your MINI worry free again. Yes, the motor is different in the F56 model. The 2011 N18 engine in yours is a good year/motor to have. Just be sure to take care of it and it will take care of you. If you ever need anything in the future please don't hesitate to let me know.
#41
#42
#44
Quote from their website:
Fits Automatic and Manual transmission models but does not have cutout for Automatic transmission fluid drain plug
#45
Well I received another call from the Mini Dealer. They said they heard the noise I was talking about, and that it was not the turbo.. It's some valve on the top of the engine.. They said it's a known issue.. Anyway they are replacing that also. I'm glad they actually heard what I was talking about.. I'm not crazy after all.
#46
So it was the valve cover ? PCV valve ?
http://www.ecstuning.com/Search/11127646555/ES2601877/
OEM MINI part number: 11127572851 : Click the picture below for item.
http://www.ecstuning.com/Search/11127572851/
MINI Valve cover Emblem Part # 11127594876
http://www.ecstuning.com/Search/SiteSearch/11127594876/ES514833/
Oil Label sticker Part # 01000419179 ( Which is used on all MINI engine bays in multiple locations dependent on year and model )
http://www.ecstuning.com/Search/SiteSearch/01000419179/
And the little yellow ignition coil sticker looks to be part #71227618790
http://www.ecstuning.com/Search/SiteSearch/71227618790/ES2674957/
And what it look like:
#47
#48
#49
Because of these issues happening as soon as I took delivery I just purchased a mechanical maintence warranty for 5 years, 160,000 miles through Endurance.
#50
Good purchase. A MINI and an extended warranty is a good idea. It'll give you ease of mind and then you wont have to worry about things like these when they arise. And of course, if you need anything I am here.
