R56 Aftermarket wheel... Will it work???
I got a hold of a set of nice (inexpensive) 18" aftermarket wheels that I was planning to put on my R56. The offset and size seem to be a good fit but the holes for the studs are too small.
It looks like the R56 has 14mm studs and the holes on the wheels are drilled for 12mm.
Now, I know there are M14 to M12 conversion studs and I'm willing to try them however my question is about the hub diameter.
I come from a BMW background where hubcentric wheels were a must but on the aftermarket wheels I have for the Mini, the center hole is much bigger than the originals.
Is this going to be an issue??? I'm not sure I'm comfortable going from a 14mm stud down to a 12mm stud AND not having the hub support that the original wheels had.
Can anyone shed some light on this? Am I being too cautious or will the aftermarket wheels be safe in the end??
Thanks in advance guys. Always great advice.
You can order what I assume would be a 73.1mm (typical universal wheel hub bore) to 56.1mm (that's a confident guess on the hub size of your R56) hubcentric ring adapter from lots of places. I usually get mine from ebay and always opt for aluminum over plastic versions. Should be $20-30 for a set. Double check my sizes.
Here is the hubcentric rings:
Includes 73.1mm to 56.1mm hub centric rings for proper fitment, there are other common sizes there to 56.1 coversion.
https://www.ecstuning.com/Mini-2007-...Centric_Rings/
Welcome.
They center the wheel and make sure it stays centered. They are hard nylon plastic type.
quickcoop
09-21-2018 03:40 PM
