R56 Intake sensor delete
So im upgrading to a larger turbo soon (gt2860rs) and I need to relocate or delete the wiring on the
intake tube. I'm sure it will throw a code how do i get around that? The stock tube wont flow the amount of air i need and I'm trying to keep this as low budget as possible without compromising too much power or quality.
Attachment 127127
Attachment 127127
Then there's new coolant and oil hoses for it, plus a 5-bolt exhaust fitting for a 3" system. And then there's the compressed air outlet --- aimed down and back, where OEM is adjacent to the inlet --- more hose elbows.
You realize this turbo wastegate runs on positive pressure, not vacuum, so you need an external BOV (aka bypass valve) and eventually some sort of boost controller to use the maximum boost available --- up to 28PSI! There's also a code to defeat --- either leave the OEM BV connected or plug in a resistor so the ECU thinks something is there. I used a 12 ohm resistor, simulating the DC impedance of my BV.
You'll need to remove a bit of structure from the underside of the hood, if you expect to close the hood --- this turbo is really big. And think about either deleting or replacing most of the heat shields 'cause they won't fit any more either.
Then when it's finally installed and running, you need a customized tune to get any kind of satisfactory results. I was seriously bad-mouthing the garrett until I got a Manic stage 4 tune. Now it's performing as I want, but most others wouldn't like its launch performance. However, it's keeping me out of trouble.
If you haven't already checked out my build thread --- https://www.northamericanmotoring.co...a-stuff-2.html --- I strongly recommend you read the whole thing BEFORE you start throwing money at a big Garrett. Yes, my "street-able" R56 has probably the most WHP of any in the whole country, but don't think it was done on a budget. There's well over $20K in it. If this is within your budget, call me, I've got this great bridge to sell you ---
Thanks for the advice. I have a new downpipe and 3" exhaust. New intercooler piping and an external bov to replace the stock setup. I have any electronic boost controller to control my boost and I've found a shop where i can get my car tuned on manic stage 4.
So I guess what i was asking is what are the wires/hoses for and where would they go on my new intake pipe setup?
If your new turbo intake hoses don't accommodate them, you will probably need to get "Tee" fittings, elbows and couplers, and build your own air intake hose system --- something I did to accommodate the OCC and BOV return hose, to retain the preferred "closed loop" system. You should try to retain all necessary harnesses and fittings as close as possible to their original location.
What vintage mini are you working with, and are you doing the upgrades yourself?
Keep us posted with a build thread?
All of this is going on an R56 hatchback with the N18 engine. I do all the work myself and i will be adding a build thread once I start.
Do you think the stock maf sensor will hold up/ be big enough to handle all the air im putting through it?
I'll have to see what kind of aftermarket options i have and how their piping is set up.
All of this is going on an R56 hatchback with the N18 engine. I do all the work myself and i will be adding a build thread once I start. Do you think the stock maf sensor will hold up/ be big enough to handle all the air im putting through it? I'll have to see what kind of aftermarket options i have and how their piping is set up.
If you're happy with the Alta filter, wait for the turbo and customize the air intake from there. Going with another CAI will be a waste of material and money. Remember, you'll have to adapt from the MAF 2 ¾" to the turbo 3" --- strictly custom stuff from previously referenced and other sources. Aftermarket kits will match the OEM 2" (or so) turbo.
Looking forward to your build thread.
Best of luck, you're gonna need it!
Slightly off topic... This is exactly how I want to setup my recirc valve. Very nice! how's the power?
Question for Green lunchbox --- what progress have you made with your planned mods?
13WSCRJCW
04-25-2016 01:13 PM
Alpha Motoring
04-11-2016 05:23 PM
Jorge Cardona
04-11-2016 07:41 AM
