Hello guys, i am new here! i cant coding a new frm in my r56 because ista-p say "you need change ulf module" i dont know where is the ULF module for check? My old frm is dead by short circuit and the new module is for my r56 but is used and need be coding. Please help me! Thanks you!
The new module frm is used. This have other chassis number and others. I need programming or coding with my chassis number and other function of my r56.
You can't code a used FRM to these cars, I've been able to trial substitute a known good FRM, but you cannot code a used FRM. They are only imprintable once.
Today, I change the MULF (Bluetooth module) and reprogram (and update) all units of the car, including the FRM used with the ISTA -P program. and the car returned to normal. I am happy
ISTA -P program BMW would not let me set the FRM ( light module ) used by EBAY buy without first changing the MULF ( Bluetooth module ) that was burned. In addition to updating all modules , bluetooth achieve it work that had never worked.
no need to change the ULF if the FRM is dead. search footwell module and you will find great information. Coding via ISTAP should be achievable. Make sure you have the latest SP datens.
I bought a new one and coded and programed with ISTA P. That program has saved me a lot trying to get this R56 running again.
How does the Footwell module get water damage? The sunroof drain is only on the passenger correct?
The rain drain is on both sides...the rubber hose gets lose for whatever reason...if you unscrew the side trip piece, you should be abke to touch it from behind the head liner. At least that was a reason for it to be damaged. I have two FRMs dying for now reason. No big deal though
