R56 Half CEL limp mode
Old 08-14-2016 | 10:15 AM
SomeguyinAZ's Avatar
SomeguyinAZ
Half CEL limp mode
So I stopped by the mini dealership so they can scan the code that's throwing it into limp mode....but they need 2hours to diagnose the problem and $140 to even take a look at it. Is this normal? I know major part stores you can borrow a scanner...and they are generic codes but is there any advantage of paying $140 for a dealer scan? Will they find the exact reason for it to trip?
I don't want to spend that if I don't need to...
Old 08-14-2016 | 10:38 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I would get a free scan or buy your own reader first. That might give you some ideas and you can search or post here for other owners tips. You can then escalate as needed to a qualified indy shop or dealer if needed. I paid the dealer for scan knowing in advance what the answer was and that they would cover the issue, so In the end I spent nothing.
Old 08-14-2016 | 11:59 AM
SomeguyinAZ
This was the code a few weeks ago. I'll check it tomor and see again. I replaced the spark plugs last weekend and getting new ignition coils this Fri. I'm right under 60k miles on my 11'
Old 08-14-2016 | 12:23 PM
Minnie.the.Moocher
HPFP, fuel pump more than likely covered under extended warranty. My 2011 was covered. Just my best guess.
Old 08-14-2016 | 12:36 PM
SomeguyinAZ
That's what I think it is too. It doesn't come on all the time. Just sporadically. I bought this car used in November from a Chevy dealer. So not sure if it's gonna be covered or not. We will see. I saw the recalls are for most n14 engines. And mines the n18
Old 08-19-2016 | 01:39 PM
SomeguyinAZ
So it was indeed the HPFP and even tho mine is an n18 engine, they said it's still covered under the extended warranty. I bought my car pre-owned from a non mini dealer. So if people search to see if they can get theirs fixed. They should be able to as well. My mini is an 11' r56s with 59456 miles.
Old 08-19-2016 | 01:53 PM
MarioKart's Avatar
MarioKart
Vendor
The early N18 motors (pre April 2012) use the older Continental HPFP. I haven't seen any N18 HPFP failures on the later models using the Bosch HPFP
mQubed Motorsport, Manic Tuning Dealer
quickcoop
12-04-2020 10:05 AM
MiniDad08
03-23-2016 02:59 PM
Badchoice
03-21-2016 09:31 AM
cersus
06-07-2002 08:10 PM
gomini
06-06-2002 04:37 PM
