R56 Lower rear only?
Lower rear only?
Personally I'm not a fan of the small rake on my 11 r56 (non-s) and was wondering how to lower the rear and level it out?
I'd like to either drop the rear .5-.75 inches and leave front alon .
Or
Drop the front .5 to 1.0 inches and the rear 1 to 1.5 inches.
I'm hoping to avoid the cost of coilovers since I'm only lowering it a bit but all the lowering springs seem to have the same drop on all 4 corners.
Any advice is appreciated
Or
The rake is an optical illusion. The factory ride height is already lower in the rear by about a half inch. The pinch weld is maybe a little bit higher in the rear, but the fender height is lower in the rear. Also, the belt line molding rakes up slightly in the rear.
That being said, you could get a set of JCW sport springs for the rear, and leave the OEM springs in the front. That will lower the rear maybe another half inch.
preme123
09-26-2013 04:00 PM
fozworth
Suspension
20
03-14-2007 05:52 AM
M3NTAL_Kev
Suspension
11
03-28-2003 02:05 PM
