R56 Yellow LED Fogs?
Yellow LED Fogs?
Ok, so I picked the OEM LED Foglight retrofit kit. I've wanted this set since it came out. Finally got the kit. Now I'm wondering something. I really like the yellow fog light look on our MINI's. But would it look ok with the LED set? Is the color going to be off if I put yellow tint on the lens?
Has anyone put yellow on their LED Fogs? If so do you have any pics?
I like the yellow bulb halogen better as the light dispersion is better in the actual fog.
But the MINI OEM set does focus the light better then those aftermarket LEDs just tossed in there , so its a diffrent ball game. If you put the yellow Lamin X on them it will be fine. The yellow will be bight and a tint of green might be seen. But thats only at sharp angles. The lights are mostly white factory with a tint of purple. I have seen then done before but i dont have pics. MN107
https://www.northamericanmotoring.co...eflectors.html
Just watch as they are hair shorter then the factory halogen fogs, might be different with the MINI OEM DRL fogs.
MINI Daytime Running Lights LED Part #63122338554
http://www.ecstuning.com/Search/SiteSearch/63122338554/
https://www.northamericanmotoring.co...-to-small.html
quickcoop
09-21-2018 03:40 PM
Omatic
03-22-2016 07:46 AM
