R56 Rough idle at cold start / vacuum leak?
Old 09-03-2016 | 11:03 AM
KWStan's Avatar
KWStan
2011 Cooper S. I've searched the archives but can't find any matches for this particular problem...
In my case, the car starts fine but after about 10 seconds I can hear what sounds like a vacuum leak coming from the top-left side of the valve cover, at or near what appears to be an non-removable round cap on the valve cover. The engine idles rough as long as the sound of air is noticeable, but the sound stops after about 2 minutes and the engine immediately idles fine from that point on. It drives great once it's warm. I have to think that there is a valve within the cover that is closing as soon as the pressure is correct, but the rough idle is driving me crazy... Ideas?
Old 09-03-2016 | 09:39 PM
Sstrickstein's Avatar
Sstrickstein
Your PCV is going bad. The sucking sound is a leak in its diaphragm. Replace your valve cover.
Old 09-07-2016 | 11:58 AM
michi1201's Avatar
michi1201
Yes. I had the same thing about 2 years ago and MINI replaced it under warranty on my 2010 MCS. No problem since.
Old 09-07-2016 | 02:24 PM
nkfry's Avatar
nkfry
As stated, your PCV has failed. If you're 100% that the valve cover is the culprit it's a quick fix but the part is about $350. I've had a couple of leaking PCV vent tubes imitate the same problem as well, and it's a much cheaper fix.
Which ever it turns out to be we have both items in stock and ready to ship.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old 04-13-2018 | 03:57 PM
Barola's Avatar
Barola
Did the new valve cover solved your cold rough/lumpy idle? Thanks.
LuckyClubbie
03-30-2016 12:20 PM
flyjets01
03-21-2016 03:03 PM
kryall
03-21-2016 09:51 AM
Lewis Lee-Martin Williams
03-14-2016 08:36 AM
andrew
08-06-2002 07:40 AM
