R56 Loud squeal at idle and driving
Well since it's been down in the teens here in Michigan my car has been making a weird noise upon start up. Normally on a cold start it would have a very annoying squeal but it would go away after 20 seconds. I thought maybe it's the belt making noise, but the belt was replaced when I had a new timing set installed. Now as of last night when I got out of work I started it up let it run for 5 minuets before leaving work and it didn't make a noise till I was under acceleration and it got louder as RPMs went up then it just went away. The noise stayed away for 5 or 6 miles until I came to a stop sign and stopped that's when the noise come back and the noise got louder all the way through 3rd gear then it went away it did that off and on until I got home. My question is is this a belt or other issue? When I got home I popped the hood and I could hear a faint sleek down by the alternator and whatever pulley is by the alternator. Is the a common noise for a failing alternator or could this be a failing idler pully of sorts? Any input would be helpful thank you.
2011 MCS
2011 MCS
Whole thing. It's in that link above.
Sometimes fuel injectors can get noisy especially with environmental temperature differences and/or age. If you have been listening out for any noises coming from your engine it might seem more pronounced now than it has in the past.
Also, If you have been doing anything around the intake hoses when you've been doing this work you could also have an resonator chamber that isn't fully seated. It will enhance the sound coming from the engine. I know this from personal experience.
Drivetrain Horrible noise coming from pulley/engine
super c00pers
10-21-2009 07:28 PM
