R56 Wheel spacer help
Wheel spacer help
I read a couple threads about them but still have a few ?'s. I have a 2011 r56 with size with 205/45/17 and I want to know what spacer size I can get without any rubbing. My second question is what do you Guys recommended for safety locking lugs I know that this is important and it's my biggest concern about getting spacers I want to make sure the fit is tight. Also what is involved with mainting the tightness of the lugs. Thanks guys
Sorry I'm an idiot i just bought my gf tires and that damn number is stuck in my head YES I have 205/45/17, thank you for your reply I was hoping someone with s lowered car would respond because I eventually would like to do that and don't want to have to buy new spacers. How much did you drop the car and can you provide pics and brand names thanks man
Those are the R90.
http://libraryofmotoring.info/facts/wheels/#17
They have an offset of +48. The same as my R112.
My car is lowered 2", and I have 15mm spacers up front and 17.5mm on the rears. It will only rub up front during very hard 90 degree cornering. Never rubs in the rear.
https://www.ecstuning.com/b-ecs-part...24ecs02a18kt2/
Those R90's are awesome. We did have a bunch on clearance sale, but they are all gone. None on sale right now, MINI has not had clearance on wheels since last year and I dont see anything in the future.
https://www.northamericanmotoring.co...-set-sale.html
https://www.ecstuning.com/Search/SiteSearch/Mini_R90/
I have the 20mm all the way around on my r58 JCW in the pics, come with the correct length bolts in black, so no worry on the fitment.
https://www.ecstuning.com/News/MINI_R55_R59_ECS_Wheel_Spacers_22836/
Originally Posted by Bleedsblue
Loose bolts? Where did that come from? My preference for studs has nothing to do with securing the hardware, just the ease of dismount and re-mount.
Does the PSS10 kit involve camber plates or no?
Cool, just checking. it's often overlooked how much negative camber helps tuck the wheels at the top
Not loose bolts, just has the correct length if you end up going the other route. Yea the studs make it so much easier to swap and change wheels. If you go the stud route then you just need the spacers themselves. When you get them all installed post up some pics. Track guys really like the stud conversion for quick change over.
