R56 Holy Crap: $6,500
Holy Crap: $6,500
Hello, all!
I have a 2007 Mini S, with around 50k miles. I don't drive much (obviously) and I don't drive vigorously. My thought process is that I need this car to last me the rest of my life. My last payment on it was in November of last year. I paid about 18k for it.
Welp, Murphy's Law kicked in and now I'm having start up issues. It just won't. The batter was replaced with the past 6 months and I have never had this issue before.
Anyway, I have a car guy who is great. He told me to bring it to a dealer because it might be a recalled part issue.
It's not. It's about half a dozen other issues and the grand total is $6,500, but thankfully, I don't need to repair everything at once.
The actual problem is that the guy at the dealer doesn't know if all these repairs will actually fix the start up issue.
My car guy is a local small shop guy who has taken absolute care of me. I refuse to go to anyone else and he asked the right questions. "What needs to be fixed for the start up issue?" Both the dealer with my CG knows I don't want to spend that type of cash (who the hell does?)
So, just a little vent and really looking to see if anyone else had the same issue and what was done to fix it!
TL;DR: Start up issues. Dealer claims half a dozen problems need to be fixed. Dealer isn't sure if this will fix the start up problem. Local Car Guy is on my side and asking right questions.
He wants to clean some valves, because they get clogged up with an S if you don't drive it all the time. I guess the oil heats and cools and heats and cools and clogs up.
Aux Water Pump, a valve cover vent hose, fuel injection thing, timing chain housing is cracked, and some oil feed lines need replacing.
If your local guy doesn't know MINI well enough find another independent shop. Dealer is the last place to go. Valve cleaning is under $500 from an independent shop. All the other stuff is a lot cheaper as well.
Dealer wants you to be priced out of repair so you will trade in for a new one.
My car guy has actually taken care of it for the past few years, up until this start up issue. It seems like a weird thing that the dealer can't pinpoint exactly why it won't start up normally.
I will keep my options open and think about looking for a local mini specific shop. Thanks. The dealer said the cleaning was about 750. Sheesh!
OK, Dealer procedures are to just throw new parts at it and hope one of them fixed the problem...whatever the problem was, they don't know. An indie, like your guy, want's to find the problem and fix it. Walk away from the dealer.
From my collection of 80 some MINI specific web sites folder, I've posted this link on NAM 3 or 4 times last week alone. Hope it helps.
http://www.minirepairshops.com/
That's exactly why the car went to the dealer in the first place, but it's actually perfectly functional at the moment and not the issue at all. :-/
I can't get video because it's still at the dealer, unfortunately, but the way I would describe it is that it's like the first 2 seconds of a regular start up and then dies. It was suggested that I pump the gas while I'm starting up but that really doesn't do anything. It has taken up to 11 starts for it to work. I can hear when it's going to work within the next one or two because it kind of lags. I know this isn't really helpful. Ugh. :-/
If it is the HPFP you will not always get a CEL so you need to monitor the high pressure fuel rail pressure when this happens. You can use Dashcommand (iPhone) or the Torque (Android) app along with a OBD2 dongle. If you see the pressure drop drastically then you can conclude that it is in fact the HPFP and you can tell the dealer what you saw, if not then move on something else.
If you happen to live in really cold weather, the throttle body can freeze and MINI makes a cold weather intake to help with this.
My car would crank then die or it would stumble and want to die. I figured it was the HPFP got an appointment with the dealer got in my car that morning to take it cranked right up no problems so I didn't take it in wasn't gonna argue with them about it. But it didn't give me a code and didn't do it all the time. I found a untested HPFP on eBay for $100 decided to give it a shot. Changed it out and no problems since.
Well, it's definitely not like with a dead battery. My battery died at the end of the last years so I have experience with what that would sound like.
I got my car back from the dealer. My car guy and them went back and forth and I decided to take it to another place because it would be cheaper. The dealer ended up changing the HPFP and from what people said in this thread, that probably was the problem the entire time. No charge to me except to pay for the gas for the rental. Fingers crossed that my car is fixed for now, although I do know the above mentioned does need to be addressed at some point.
No offense to your car guy, but most of us here have been around the block with these cars and unfortunately a good car guy can sometimes be stumped by a MINI. That is why we always advise you to find a quality MINI independent shop near you. The MINI dealer is always going to be the top price and not always the best work.
I have several car guy friends and they can build you a big block ford or Chevy with their eyes closed. But a MINI branded, BMW made, Peugeot engine with direct injection, turbo charged, oil burning, clogged intake valves, timing chain eating motor is not something for them to diagnose.
Now, Go drive that thing like you stole it and have some fun.
Originally Posted by 05r50
Sure. Your gas pedal is connected to an electronic wire. It is not a mechanical rod. So it isn't pumping any gas.
Now it is all computer controlled. There are even cars now with brake by wire and steer by wire systems.
That is really good news for you. Hope this works out for you.
Thanks all for the advice! The best advice was "dealer is the last place to go". My car guy and I stood our ground and we're glad with the results.
actually if you are old enough to remember carburetors they (or at least some) indeed had an accelerator pump to literally pump an extra squirt of gas each time you floored the go pedal. (You could sometimes even hear it squirt the fuel). I'm sure this is the origin of folks 'pumping' the pedal while trying the start even though it no longer does anything.
of course...the accelerator pump adds excess fuel to richen the mixture on top of what comes from the jets.
