R56 Thermostat replacement gone bad
alright so I have a 2011 hardtop with the 1.6 (I'm pretty sure the motor is). well I replaced the thermostat sort of.... lol. when pulling the old unit the extended part of the thermostat housing wraps around the back and connects into a piece with a pin of some sort. I'm new to Mini/BMW so I'm all sorts of lost but I seem to have broke it anyone know what that part is called and how hard and how much of a pain it is to replace I need help asap thank you
By the way, it is easy to replace. It just slides into the water pump with no fittings or clips. I actually ran my arm down the back side of the engine (from where the thermostat housing is to the passenger side of the engine) until I found the water pump inlet so I could get an idea of how to feed the pipe.
Alright well it didn't work I can't seem to get the water pipe free from the back of the water pump there was a electric cable clipped into it but I freed that why is it so hard to free the o ring on the pipe to free it from the water pump maybe I just pulling the wrong way I don't understand haha one of the guys I know works at a dealer and they had a mini come in and he said when he changed the pump he had to drop the motor I'm hoping I won't have to do that
Here is the DIY if that helps. You need to get the thermostat out of place and then pull the clip and wiggle out the water pipe.
Water pipe wiggle:
https://www.northamericanmotoring.co...hermostat.html
DIY:
Water pipe wiggle:
DIY:
Welcome, sounds like it just did not want to give up.
