R56 Sway bar end links?
Vendor
Actually we feel that most the aftermarket end links are junk. Using the heim joints on the links just leaves them exposed and we often see within a week of a customer installing them they start clunking and rattling. Not to mention the price you pay for them to make noise.
So if you just have a street car and are not corner weighting it, racing it, or extreme lowering the cheapo stock links will work fine for you. Many MINI aftermarket companies selling sway bars lie to customers telling them they "have" to get their aftermarket links cause the stock ones are week. That is total BS as the stock one are usually far more reliable than the heim joint ones they want to sell you.
https://www.waymotorworks.com/sway-b...7-r58-r59.html
But if you want aftermarket with the ability to adjust we have ours that have the sealed ball sockets so they don't make noise and solid steel center shafts that are super strong. Been using these on my race car for like 10yrs plus and haven't broken or worn one out.
https://www.waymotorworks.com/wmw-ad...-endlinks.html
Also the steel shafts are much smaller than most the cheaper aluminum ones. This is a huge advantage as ours will fit better and give you more clearance as the larger ones like the whitelines and other similar brands the large aluminum centers can get in the way and often are heavier than you would think.
fonseca (10-13-2020)
Originally Posted by Scooter24
How long have you had them? I was looking at power grid end links, they are $155 a set. The whiteline are $120 I'm not sure if one is better than the other or not.
I want to corner balance the car to optimize everything I can get out of it.the adjustable one you guys sell are they worth the extra 30 bucks compared to the whiteline?
This would be one of those times where the phrase "You get what you pay for." applies. Way and Detroit Tuned make very similar links for I believe the same price. Both are vendors who strongly support our line of vehicles, won't steer you wrong and stand behind their products. Let the Honda's run that made in China crap.
Vendor
I do feel ours are better than the whiteline. The biggest reason is cause the size alone trying to make then clear everything and not bind or hit the control arms.
But I also feel the quality of the ball sockets is much better and know they last as I've been using them for so many years without issue.
But if you still want the whitelines we're happy to sell them to you too
https://www.waymotorworks.com/whitel...bar-links.html
I support our sponsors as much as I can. Just hard sometimes when you're a College student. $60 dollar difference is a lot ha. But I don't want to skimp out and I want what's best. I do have a question about corner balancing. When it's done, adjusting the away bar to add or remove preload part of the procedure to corner balance or is that only on adjusting preload on the coilover spring?
I should have proof read my last post. Adjusting the preload on the sway bar, is that part of the corner balance procedure? Or does corner balancing only involve adjusting the preload on the spring on the coilover? I'm paying to have it done since I don't have scales. But I'd still like to understand how it's done.
