R56 Wiring up marshal temp guage.
I'm going to be installing the marshal temp guage and I have a few questions. When doing the wiring connector 4 pin 1 is always hot, pin 3 in ground, pin 5 is 12v when ignition is on and pin 4 in 12v when connected to the dash light wiring. Can i just wire pin 4 and 5 to the same spot? Also when the back light for the guage is wired into the dash light wiring will the guage dim properly when the dash lights are dimmed? I'm not a huge fan of electrical, thanks.
The Marshal gage lights are led lamps and will not dim when spliced into the MINIs dash lights, they are either on or off, but they do come on when the headlight switch is turned on. The dash lighting circuit voltage varies with the dash light dimmer switch position.
For that reason you should wire the gages as per instructions, if you wire the gage power to the dimmer, the gage will read erratically, depending on the dash light brightness or if you wire the gage power and the gage lights to constant twelve volts, the gage lights will be on all the time.
A stepper motor gauge is a type of gauge that uses a stepper motor to move the gauge needle. A stepper motor moves the gauge needle in discrete mechanical movements.
I don't think Marshal gauges use a stepper motor movement, they use a d'arsonval meter movement, which is a moving coil DC movement, they move the needle smoothly.
The Marshall temp gauge I have is a stepper motor. You need an adapter to connect to the dash lighting circuit, there's a thread here with the details.
https://www.northamericanmotoring.co...r-dummies.html
