R56 Average cost to rebuild N14 engine?
So to make a long story short I skipped a step on reinstalling the timing chain (which I've done before) and next thing you know when I started it realized that it was not timed correctly so to put it shortly the engine doesn't run and needs to be replaced. I'm currently the opposite of Bill Gates (college student) and rely on this car a lot! I've done all the repairs to it myself and never had a problem until now. Question for you guys. What is the cost to rebuild one of these suckers? I've seen rebuild kits that come with CP pistons, head gasket, head bolts, etc for about 1300- 1500. This kit does not come with rods. (Do the rods need to be replaced? not going to increase hp). Obviously, the head will be machined and the block will be honed then I'll have a buddy of mine fly over to help reassemble it. What other cost will I occur? anyone out there done this before? Is it cheaper to go with a rebuilt one for $4000.
Doing your own labor should keep the cost well below 4K, even with machine shop work. Rods are pricey and will add a bunch if replaced. First order of business is teardown and inspect --- can't price it out 'til you know what needs fixing.
there is something missing here! when you mis timed the engine, the worse thing that could happen is bent valves.
with %90 leakage on the piston, it depends on the damage. either way you will be removing the head. once you see the damage, it will be easier to execute the plan.
I did a rebuild for a fellow NAM that included a used block, used crankshaft, new crank and rod bearings, one used piston, new 4 sets of rings, new set of valves, vac pump, timing chain kit, for about 2800 installed.
thanks for the reply. Is it possible that the bent valves are showing the 90 percent leak and the pistons are fine? I'm currently in the process of removing the head however right before I started I shoved a camera through the spark plug hole and only saw some scratch marks from the valves. Maybe the pistons are ok?
