R56 Emission test question
#27
I am glad to read this! Just moved into Western New York, and I was curious if I would pass emission testing without swapping out my down pipe. I have a cat-less down pipe and Manic Stage 2, and have previously passed Connecticut state emissions testing.
#28
Been getting inspected in NY on stage 2 and 3 tunes for 4 years now, never had issues just leaving it on a Manic map and getting inspected. NY allows one not ready monitor as long as there no CEL.
#29
#31
#32
In NY you're allowed 1 NOT READY code w/ no CEL. If you are catless then that's the one permanent not ready code. Clearing all codes before you go get inspected will result in a fail, because you put everything in to the NOT READY mode. But, if you're getting a CEL for the Evap System then that will put you over the limit for codes and you will fail.
#33
Again I’m stage 1. Totally stock exhaust. All cats intact. Fairly certain even stage 1 causes a non readiness code for cats- hoping switching to stock will get that 1 to pass. In regards to the evap code I have no idea. Can you find out what it is through the scangauge or do I have to purchase the dashcommand app?
#34
Unfortunately you’re going to have to address the evap issue
Z06C5R
08-10-2016 03:23 PM
Drivetrain What codes do you guys get running catless?
johntotah94
09-29-2013 07:04 PM
