R56 Auxiliary coolant pump
2009 Mini S: Anyone ever get their auxiliary coolant pump replaced under recall? I noticed some coolant leaking and the garage said they pretty sure that the pump is the problem based on where the leak is. To confirm 100% they would have to pull it all apart. My car does not have the dealer label that the recall was performed. If I check mini's site with my VIN it says there are no open recalls on my car. Here is the recall... https://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM416347/RCRIT-12V008-6688.pdf Recall # SI M17 02 12
Even though my problem is a leak and possibly not what the recall was actually for it should still get the pump replaced right? Figure it is worth a shot...
The garage actually referred me to recall SI M11 01 13 but it is only for a 2012.
Yes it was for the aux water pump. If its been done then your vin is not under the recall anymore.
https://www.northamericanmotoring.co...ll-letter.html
But this is the newest pump which is the one that would have been put in when the recall was completed by MINI: 11537630368
https://www.northamericanmotoring.co...-starting.html
