R56 FRM Module brick, a bit of info.
Hi! I'm from Italy so I have an european mini Cooper r56, I was surfing the forum when I saw that many users have this problem!
The problem is that when you change the battery and disconnect it,you will brick the FRM Module, obviously not on all car this is happening.
After Reading all these situations I'm scaried to disconnect the battery or do codings with bmwhat carly app!!
For the coding with Carly: I don't think coding a new battery will reset the FRM module right? So I Can stay sure?
For changing the battery just:
Disconnect "black" cable (-)
Disconnect "red" cable (+)
Connect "red" cable (+)
Connect "black" cable (-)
More than 20 battery changes on R53/R56/F56 without any problem.
Just be careful and avoid playing with the cable againt the battery terminals. That's the problem. Innecesary sparks.
Battery reset (coding) is not related with FRM.
FRM is the "lights" (and other stuff) controller.
You will be resetting the battery age counter on car computer and it will be modifyng only the way the battery will be charged...
Moderator
NintenTom
Electrical
54
01-30-2019 07:50 AM
cjv2
01-16-2019 03:35 AM
R50/53 Crackhead, a Brick & my MINI
joedude99
12
07-02-2003 08:45 AM
