R56 Aftermarket headlight with both DRL and LED low beams?
Hey, I'm after an aftermarket headlight with both DRL and LED\Xenon (for low beams), if someone know about such thing.
My mini currently got simple halogen headlights which sucks.
So far I came with some nice DRL headlights but no LED\Xenon for the low lights bulbs.
Thanks for the help!
Moderator
Found this tho:
https://www.ebay.com/itm/For-07-13-B...kAAOSwm8VUwzGc
Could be a good option....sure would like to find someone who has purchased a set....
There is Xenon version here of the halogen versions from spyder. You could use a kit and convert to xenon/ led with the xenon kit?
https://www.northamericanmotoring.co...ve-at-ecs.html
I have these https://www.ecstuning.com/b-helix-pa...ni07hl-oeb~hl/ with https://www.theretrofitsource.com/h7...C54412%2C47697 Be sure to get the canbus and not the relays. I don't have any issues but I previously had the bulb checks turned off so I could run all LED bulbs.
Thanks for posting up, that's another option if you want the oem black line look.
Another option woud be these http://www.ecstuning.com/b-spyder-pa...-yd-mc07-hid-/ and these https://www.theretrofitsource.com/d1...n-35w-45w.html but you would still have to get bulbs and have your car coded for xenons and I'm still not sure if it'll work. I would call the pro's at TRS to see what your options are.
Elemento1991
Electrical
09-12-2016 07:47 PM
Rodrigo Constantino
11-12-2014 09:51 AM
