R56 Headlight swap
Have you looked at the aftermarket ones:
https://www.northamericanmotoring.co...eadlights.html
More info on link and install.^^
On the OEM genuine MINI bi xenon headlights retrofit:
https://www.northamericanmotoring.co...rofit-kit.html
Vendor
With the factory Retrofit kit you just install them then have to have the car recoded. We do the install and coding for free when customers buy the light kit from us.
https://www.waymotorworks.com/xenon-...7-r58-r59.html
I'm seriously looking into this.
I have halogens on my car (which I hate) and want to get the Xenon HID type of lighting and wasn't sure which light set up to get.
I want OEM operation but don't want to pay OEM pricing. I know I want headlights that are black (not grey) and not sure of the difference between the spyders and OEM.
Not really feeling the retrofit kit. So which lights would work flawless on a 2013 R56 JCW?
Vendor
If you want black headlights going to the factory black set with the proper wiring and coding would be ideal. That is how I did my clubman as I also wanted them to be black.
Looking at all options for this conversion from halogens to xenon and I found a set of silver housing clear lens xenons at a local wrecking yard for $500. Supposedly they are in perfect condition (insurance grade A.)
If I go with the used ones rather than the MINI retrofit kit, is there wiring involved in addition to coding or is it plug in, code, and all good? If I have to mess with the wiring I'll definitely go with the retrofit kit.
Vendor
Thank you, retrofit kit with new OEM lights is starting to make sense for my situation. Now need to convince my partner that we have to have this.
do you sell the black factory HID set with the proper wiring? I'm assuming this is an OEM set up?
Has a Plug and Play HID/Xenon kit been developed yet that one can do a direct swap for 2013 R56 that came with halogens?
I just want something simple that will work like OEM in my car and give me HID/Xenon look, without all the fuss with trying to do ballast swapping, cutting the lights open and retrofitting something inside in order to get the look I want. Also would like HID foglight kit too! Anything from Way or ECS or another company that I can go to that already has this lighting issue (going from halogen to Xenon) figured out. Which link from the above posts is answer/fix for what I need to get?
bbak11010
09-07-2015 08:08 PM
bbak11010
09-07-2015 08:03 PM
wai_jai268
05-28-2015 07:24 PM
