R56 Help Guide | Windshield Wipers
Windshield Wiper Blades Guide for
MINI Cooper R56 Hatchback/Hardtop (2007-2014)
Maintenance for your MINI Cooper is important for the safety of you and other drivers. Windshield wiper replacement, especially during winter season, should be a routine.
Through time your wiper blades become dry, cracked, and damaged from different weather conditions. Worn out blades can impair your visibility, increasing the chance of a possible accident.
Check your windshield wipers every 6 months. If they’re creating squeaky noises, leaving streaks, sticking, or other abnormal issues it’s time to replace your windshield wiper blades.
Wiper Blades Size
Drivers side = 18" | Passenger side = 19" | Rear = 10.5"
Understanding Arm Types
J-Hook "Old" Style
For the Gen2 MINI R56 it’s pretty easy. They used the same J-Hook Blade ("Old" style)
Bayonet Style
To remove the wiper blade, squeeze the tabs on the sides of the arm and pull the blade off. For installation, the wiper blade simply slides onto the arm until it 'clicks' in place.
How to Install Wiper Blades on MINI R56
J-Hook Old Style:
Bayonet Style:
OEM or Aftermarket Wiper Blades
OEM
There are many reasons for purchasing OEM windshield wipers.- The blades were built to specifically adhere to your windshield
- Longevity: OEM ensures that the windshield wipers will last long, since they fit your car perfectly
- Proper Functionality: You can assure they are going to fit properly and work since they are made for your car specifically
Aftermarket
Why use PIAA and Aero Vogue?- Durable: Silicone rubber lasts at least 2x longer than traditional blades
- Performance: Silicone compound promotes water beading and quiet operation
- Refillable: AeroVogue and Super Silicone wipers accept Silicone refills
- Better Value: Long-term costs are lower due to outstanding durability and refill capability
Choose Your OEM Wiper Blades (2007-2012)
FrontOEM Streak Free Front Wiper Blade Set
Rear
OEM Rear Wiper Blade
Front & Rear
OEM Wiper Blade Set 3 Piece Front and Rear
Choose Your OEM Wiper Blades (2013-2014)
Front
OEM Front Wiper Blade Set
Rear
Front & Rear
Choose Your Aftermarket Wipers (2007-2012)
Rating: Good
PIAA Super Silicone Front Wipers Blades
Rating: Better
Aero Vogue Front Wiper Blades
Rating: Best
PIAA Si-Tech Silicone Flat Front Wiper Blades
The following 3 users liked this post by Mini Mania:
R50/53 Windshield Wiper Refills
wardellcastles
04-03-2007 09:34 PM
