R56 2008 r56 cooper s n14 auto tranny removal insight required
Hi new member looking forward to diving into the mini community. Just picked up an 08 cooper s with auto trans that is slipping in 4, 5, and 6th. Drives fine in steptronic mode gears 1,2, and 3. Just looking to swap with used tranny since it's relatively inexpensive but had a question regarding the removal process. I know in the 1st gens I see the tranny can be removed while leaving engine in place, Is this the same for the 2nd gen autos as well or do I need to pull it with the motor? Pictures suggest there might not be enough room to maneuver away from block due to the frame being in the way to pull out from the front. If anyone has any experience it would be greatly appreciated.
Yeh I forgot to mention im on jacks stands so I won't be able to drop the sub frame. I have the nose off and engine supported but can't tell if there's enough room to pull off the housing from the block. I guess I'll just have to try.
Norton70
R57 :: Cabrio Talk (2009+)
08-18-2015 04:29 PM
