R56 Trunk lock warning light
MiniToBe The trunk open and Close normally, the only problem is when Stop/move the car, warning light show. It could be something into the junction box ? or the wiring sensor is cut in somewhere?
https://www.newtis.info/tisv2/a/en/r...button/cjbLDL3
https://www.newtis.info/tisv2/a/en/r...tlputs/cjqo8IJ
The middle diagram shows the boot lock and on the second link, it is the last connection going to the fuse box.
When the light comes up, can you verify the lid is closed. bush on it to feel for space. Mine used to do that. Also, check if the lock itself actually closes all the way. open the hatch, and use a screw driver to push on the latch as if the hatch is closed. then drive to see if the light comes again.
I Will try. When finish I will send a feedback
Lombomini2009
02-12-2014 04:16 PM
flee
12
09-19-2013 10:30 PM
Aviators
02-15-2006 03:58 PM
