R56 Spare tire carrier not tight
2009 Base.
Just checked my spare tire carrier and it has play in it. I can wobble it a bit from side to side. Not a big deal, but I'm thinking it may be giving me a bit of a rattle when driving.
I removed and inspected it and the bolt is tight.
Is there a bit of play in your carriers or are they tight?
I found the source of the problem.
When you snap the spare and carrier into place, three rubber pads press against the wheel of the spare.
I glued three additional pads over the original pads, which were worn. I also added a rubber gasket around the center hole of the wheel where it will meet the carrier.
All is tight now
All is tight now
ECSTuning (02-06-2020)
