R56 2011 Cooper with Issues How Bad Is It?
Just picked up a 2011 base from auction, 78,000 miles. Turns over, but intake cam suffered some damage and I'm guessing at least the head has to come off. Timing chain did not break and I'm hoping bottom end is still good. Metal flakes on valve cover. How bad is it? What should I do first/ what needs to be checked?
Groove on camshaft from spring
Metal flakes
Retainer cracked
Retainer cracked
Retainer cracked
Metal flakes
Retainer cracked
Retainer cracked
Retainer cracked
theyboosting (02-03-2020)
One of the rollers, lifters, or followers (not sure what it is called) is missing. Looks lik it got spit out. The cam also is scratched up where one of the caps broke. I have ordered the timing locking tool so that I can remove the cam and inspect the seat. I will start as you said with replacing the parts and doing a compression test.
The cam caps on my '07 MCS are part of the head and not replaceable --- cam journals are line-bored, no bearings. Check RealOEM for cam cap part numbers --- if none, they shouldn't be replaced.
With metal shavings, any rebuild should include a good hot-tank flush of the bare block and head (if re-used) to get rid of shavings in the oil passages.
Best of luck ---
Best of luck ---
