R56 Wheel Fitment
Wheel Fitment
I just purchased a set of Sparco Terra Wheels 16x7 4x100 et42, I figured I'd stick close to stock and get a little wider rim so I can put 205 55 r16 on them for more grip and im not a fan of the stock runflats. I know OEM fitment requires et 48 for 195 55 r16, my question is will I need wheel spacers for the sparco wheels? Im on stock suspension so im too worried about rubbing more so if the rim will clear the caliper.
Erick Fraile (02-08-2020)
I have had pretty good luck using this site for determining wheel clearances in the past. You can measure your current fender clearance now and plug it into this computer to compare, but I am thinking everything should fit fine on stock suspension.
https://www.wheel-size.com/calc/?whe....1875in&sr=0in
You are already pushing the wheeel ouboard by 6mm moving from ET 48 to ET 42..... so I would try what you have and look closely for clearance issues... I doubt you will have any. Also... on that same car... optional ET 48 x 7", 17' wheels are mounted at the factory with 205 tires.... I think you would actually have MORE clearance with your setup on those Sparco Terras with the 205/55/16's than a factory 205/45/17 on factory wheels.
