Cylinder Head is off what to do "while I'm in there"
Hi guys, my R56 MCS (N14) has bad valve seals and I need to pull the head on it. What are some things that should be done "while I'm in there"?
I've already got: timing chain job, VANOS solenoid, vacuum pump, thermostat housing, better valve springs, and the head gasket. What else is easily accessible with the head off the engine that I should be taking care of while the heads at the machine shop?
Yes the valve guide seals. It'll also give me easy access to the combustion chamber so I can clean the carbon off everything while it's off.
You do not have to pull the head just for seals. I just did my '07 MCS valve guide seals along with the timing chain and front main seal. No more blue smoke. No head removal.
