R56 Suggestions for additional proactive work when replacing the timing chain & tensioner
About 6 months ago, I purchased a 2008 R56 S with 48,000. It now has 55,000 miles and I am starting to budget to replace the timing chain and tensioner. Is there additional proactive work that makes sense to do at the same time as this work? Thank you in advance for advice.
Michael-Mini (02-25-2020)
Valve grind / re-seat, and stem seals. Will improve performance and help with oil consumption / burning. Disadvantage is gotta strip everything off the head for a machine shop, unless you DIY, but even then you'll need a gasket set for all the "stuff" removed and re-installed. Also need a special tool to re-install FI seals, unless your local shop has one. Gasket kit will include all the above and herein mentioned head stuff EXCEPT the main head gasket, which is available in two thicknesses. Either one should be OK, even if the head is "shaved" to remove any warpage.
Philip J. Frye
03-11-2020 05:42 AM
rondayvous
02-18-2019 11:09 AM
paultu1985
04-10-2017 06:05 PM
