R56 Cylinder liner flange wear
I agree with MiniToBe. You could do nothing and be just fine, however, I would suggest you ensure the top and cylinder wall portions of that damage are fairly smooth when running your finger across it. The top being smooth for gasket concerns and the cylinder wall being smooth to prevent any hot spots. High spots tend to get hot during operation and could lead to detonation during operation. Some emery cloth applied to it should ensure there are no high spots. Aside from that it will be fine.
Technically, I'm not sure what you're referring to when you say, 'machined,' but I can make an educated guess it's the mating surfaces of the heads and block. If this assumption is correct and unless there is known damage to your block, no, your 'machined' head and block should mate up well.
With only 40K miles on the engine, I gotta wonder why it's all apart. Then with about 20K miles of track driving, there's a good chance the cylinders aren't round any more. Just replacing rings and waiting for them to seal is gonna cost you a bunch of oil and reputation at the track --- smoker. If you're replacing pistons too, the 77.5mm will be the same price as the 77.0mm and you get rid of all the cylinder defects.
As for the cylinder "ridge", there's a special tool called "ridge reamer" designed for the DIY crowd. Pretty cheap and easy to use. That little section of missing material shouldn't be a cause for worry, but a cylinder over-bore to 77.5mm would remove it and the ridge.
CantComplain
01-14-2019 07:01 AM
