R56 Battery cover fix
Battery cover fix
Hello Guys,
I bought a pretty clean 2010 MCS last fall but unfortunately I didn't really have time to enjoy it much before I had to store it for winter (winters here last forever). One of the first thing I noticed when I purchased it was the battery cover had separated from the R/S Apron. As I stored the Mini for the winter, this kept popping in my head. How can I secure that annoying cover and keep a factory look (I wasn't digging the duct tape fix). Looking around for a better solution, I found small plastic hinges on ebay and an aluminum thumb screw on amazon.
So I proceeded with the fix.I didn't center the thumb screw with the cover because I didn't want to have the threaded portion right on top of the battery (it is pretty close, it would have cleared by just 1/8"). Plus now it falls right into pocket area of the hood, so there's no chance of interference with the hood itself.
All in all, I'm pretty happy with how it turned out. Let me know what you think
Thumb screw aligned with hood pocket
Hinges barely visible when hood is down
back side of apron
back side of apron
The following 3 users liked this post by Mini-wings:
Beauty is in the eye of the beholder, so I will refrain from commenting on it. However, water intrusion would worry me. Considering that hinges, screw and shipping do not come for free either, I would have opted for a new apron cover instead (whether from a junk yard if in good condition or new altogether).
ECSTuning (07-01-2020)
Yes, i just worry that water would get in their past that flap near the battery and if at the correct angle it can get and pull into the cabin filter inlet.
https://www.realoem.com/bmw/enUS/sho...diagId=51_6604
Realoem is not correct on prices they are like estimate and always lower most of the time, you cannot buy off them also. We have it here, If you need help installing i have done mine a couple times and you can PM m.
https://www.ecstuning.com/b-genuine-...-/51132751210/
I tried reinstalling the firewall cover, but it just would not go on like it did before.
Any suggestions would be greatly appreciated.
Thank you,
Oscar
I also had some trouble getting the new piece to pop back in correctly. When I replaced mine, there's a plastic mounting piece that attaches to the bottom of the windshield that was coming off. After I used a little glue to reattach that I was able to pop that left apron piece with the battery cover so that it was nice and flush against the windshield.
MaximusMini_TX (01-03-2022)
Yes there is a piece in the middle that if not set in correctly will not let the piece seat right. Also that mounting strip needs to be on the bottom of the glass correctly, its like U shaped and the other U shape clips to the bottom of the glass.
https://www.northamericanmotoring.co...ld-cowl-3.html
Issigonis I am curious if the plastic hinge strip worked. I am considering this one.
Both mine were broke off when I purchased the 2012 Coupe last January. If that doesn't get it, Black Gorilla Tape to the rescue. I really do not want to purchase new as the rest of the cowl is fine and I know this is the "weakest link" of the whole cowl.
