R56 Thermostat housing
I literally JUST replaced my thermostat for that code today! Hopefully, my code doesn’t come back.
I assume you are getting new thermostats under warranty each time?
Have you replaced the harness adapter?
Production up to 7/12
https://www.ecstuning.com/b-genuine-...r/12518611289/
Production from 7/12 to 2/13
https://www.ecstuning.com/b-genuine-...r/12518614952/
Did some quick search, and it looks like you don’t need that kit, only the early N18 cars.
I would check the harness connectors to make sure there isn’t any corrosion on them. If there is, I believe ECS can get new connectors to splice onto your harness. I would find it hard to believe three thermostats in a row would have issues.
P0597 is heater control open circuit. Depending on the year and type of thermostat you have the one on top, but also a connector at the lower back. The P0597 should be associated to the connector in the back AFAIK. As others mentioned, you should see some resistance between between some of the pins (maybe it's X6279 in Newtis). You should check the pins in the connector, and also check for continuity to the DME connector.
https://www.bar.ca.gov/Industry/Indu...ble_Codes.aspx
Notice paragraph 1. To clear a permanent code, you need to fix the problem and let the car determine that the problem isn’t there anymore, and it will clear the code on its own.
Not sure if this is your case or not, but that’s what I’m currently dealing with after replacing my thermostat.
ricbow
08-20-2023 03:40 PM
