R56 2013 R56 base cooper. Power window motor will not stop turning
So yesterday I found smoke pouring out of my door.
It smelled electrical so I ripped the battery out, took apart the door and found that the driver side window motor was insanely hot.
I managed to make it to my local junk yard and pulled a replacement window motor. I plugged it in and the issue became obvious, the window motor is stuck on, and is pushing the window up constantly
This happens even if the car is off and the keys are out, even if the car door is locked.
I also found that if I push the down button while the car is on, the motor will suddenly stop for a half second, then continue turning in the up direction.
Any ideas, my first thought is dead footwell module but I am unsure, and I know that is the most expensive possibility
Also if i open the door the window doesn't go down, it continues turning up
I should clarify as well about what I mean when I say the car is off and it still turns.
I could leave the car locked over night, come back and just unlock it, plug the motor in and it starts turning as soon as the wires get connected.
same if I lock myself in the car the motor still spins.
if I unplug the battery and plug it back in I think it does the same thing, starts turning immediately after the battery is reconnected
Thank you for the site btw I am shy of resources and have been using a Haynes manual but the wiring diagrams are pretty darn vague in it.
I'll maybe carefully tear it apart this weekend to minimize damage. Maybe pull a spare from the junkyard while I am at it and anything else related so I can easily go down the line and rule out everything.
I'll update as soon as I test it out
dfatherree
04-23-2020 12:48 PM
