R56 Silicone tubing or not.?!?!
Hello guys.
I'm keep buying stuff till i fit them all together in my baby boy!(JCW N18)
Now because of i'm almost finished i have this question..
Should i make ALL of my tubing in silicone for both coolant+air or not?
I 'm not expecting to earn something besides the "insurance" that everything is new+enough and it will last longer without any cracks like plastics etc...I might earn something with the inlet hose etc but this is not the main reason(any extra response/power is welcome ofc)
After some research i find out that these are ALL the hoses that mini have an i can replace them with silicone hose....PLEASE correct me if im wrong.
https://www.lohen.co.uk/samco-boost-hose-kit-gen2
https://mtcmotorsport.co.uk/catalog/...6/category/92/
https://www.ebay.com/itm/Mini-Cooper...r=453388749787
https://www.ebay.com/itm/Mini-Cooper...r=451566661141
https://www.ebay.com/itm/Mini-Cooper...r=453134434377
1..Is there any pipe missing?
2.Is there any pipe that is double and i cant see that?
3.Will all theses pipes fit in my N18 +Aem Intake+Wagner Cooler?
4. ANY -CONS except the money/cost? Any better solution for hoses in general or for some...For instance hard tubing and not silicone?
5.Should i avoid any brand or should i choose a specific brand??Personaly i believe that most of them made from the same factory with same materials/machines and different labels....However is that correct? Should i go with Samco?Forge?Mishimoto?Ikon?Mtc? or should i avoid any of them?>
Thank you all for your time i cant wait for your answers.
Cheers!
Cheers!
Before you decide on silicone for the coolant hoses, do your research and see if that’s what you really want to keep up with and maintain. You will lose volume of (coolant/water) liquid through the silicone hoses because the pores are larger than that of rubber. They are in fact longer lasting and more durable but they have that drawback.
Thank you for your reply.!
Yes i'm aware of that and that loosing its like meaning i will add 2times more of coolant and that is fine for me...Id rather waste some $$ more for fresh coolant and be sure of my hoses rather than having cracks etc etc.
Any help idea for the rest of the questions i made above?
I would really appreciated if you could also help me with them.
Thank you
Hey friend.
Thank you
Thank you
As far as other stuff being Silicone, go for it.
Silicone I have:
Turbo Inlet to intake tube
Turbo Inlet to Intercooler(full silicone pipe)
Intake tube to MAF
Intercooler discharge pipe to factory hard pipe
Need to get:
Intake hard pipe to intake manifold
The following 2 users liked this post by Mr. Booshie:
Staxtis (10-14-2020),
Zeyk_Shade (10-21-2020)
It’s more than just losing some coolant, it will seriously skew your coolant/water mix ratio depending on how you address the issue.
Silicone I have:
Intake tube to MAF
Need to get:
Silicone I have:
Intake tube to MAF
Need to get:
Can you mention with link/photos the parts you have?
Thank you.
Silicone I have:
Turbo Inlet to intake tube (part of intake system)
https://nm-eng.com/collections/mini-...31236976181292
https://www.waymotorworks.com/forge-...lete-hose.html
Intake tube to MAF (part of intake system)
https://www.waymotorworks.com/forge-...tlet-hose.html
Need to get:
https://www.waymotorworks.com/nm-air...ipe-black.html
pluffmud
02-05-2020 06:54 AM
Drivetrain Anyone with a home built IC pipe set?
S4SF
R60/61 Cooper S Drivetrain
10-19-2015 04:30 PM
