R56 TPMS control module location
Hello,
I've changed all four TPMS sensors on my 2012 Mini hatchback base but the check light is still on. The mechanics says the diagnostic tool returns a control module problem.
www.ebay.com
Does anyone know where that module is located for that year/model? The mechanic couldn't find it.
Thank you.
Mini Cooper TPMS Control Unit OEM Gen2 R55-R61 | eBay
This is the receiver that monitors the sensors in each wheel.www.ebay.com
Thank you.
Make sure you check your electrical connections for water intrusion/corrosion. The location is bad for that control module. I've got a 2012 Justa and had a bulb out indication for the reversing lights. When I went to check the bulb, the entire light assembly (near the TPMS control module) was flooded with water.
Cyama
03-17-2021 06:14 PM
