R56 P1497 very rough idle.
So, I've had this code for a while now. It comes and it goes, but now it's gotten much worse and is also accompanied by some others 2B64, 2B51, and 2B5F. It idles really rough, almost to the point that it's going to stall. While driving it, everything feels fine, but when I idle it goes crazy at cold start and before it warms up. After driving it a while, it seems to calm down, but you can still feel a slight jump to it and when I stop it jerks a little. The last time the code popped up, I ended up replacing my throttle body and PCV hose (it was cracked) and that fixed it for some time. I removed everything down to the throttle body again, but didn't see any cracks or breaks in any of the pipes, outside of a small hole in the bottom of the noise maker air channel (see below). I'm not sure if that's supposed to be there or not. Along with that, I have one of the clips to my cold air intake box broken off the back. Not sure if these two things could be throwing the code or not, but wanted to be thorough.
I haven't done a smoke check or anything like that (I'm not even sure how to), but the last thing I've checked is the VANOS solenoid on the back above the intake valves. I didn't see any noticeable crud on it, but it hasn't been replaced since I bought the car back in 2011. Should I replace them, do a noise maker delete, get a new air intake box? I'm not sure what's causing my issue, but the car is not very fun to drive at the moment. Appreciate any help.
Have you solved your issue yet? I just ordered the solenoid and hope that solves my problem. I replaced my thermostat housing last December and when reinstalling installed the same noisemaker delete. I’ve driven the 08 MCS a few hundred miles since it was put back together and it was running beautifully. Then today it went to sh*t. Extremely rough idle, lurching while driving. A number of codes including P1497. I’ve got 213K miles and am the original owner.
I would get the code every once in a while. Seemed to happen when the seasons changed, for whatever reason. But eventually it was constant and rough idle was present more for the first spin of the day. The more I drove it, the less noticeable it was, but it was still there.
MiniS08
10-08-2020 03:38 AM
