R56 Reading the dipstick
Checking the oil, I see it reads low, except if I rotate the stick, there is a line of oil on one side that reads nearly full. This is repeatable. Since tracking oil consumption is important, how do I get a reliable reading?
It was easier to see outside, but difficult to photograph...
Thanks for advice.
Thanks for advice.
The CravenSpeed dipstick is nice but definitely expensive. I found a similar product on Amazon for under 20 bux. I did have to trim the spring to the correct length, which took me about 5 minutes. Just measure using your stock dipstick, Loosen but don't remove the set screw, cut the spring to length, reinsert and tighten the set screw and take your readings..
bratling (08-20-2021)
Lots of of threads on this question. This dipstick is hard to read due to its shiny finish and the S shaped dipstick
tube smearing the dipstick with oil any time to put it back in and remove it. However there's a work-around to it:
- use sandpaper to remove the shiny finish for a matte finish and thorougly clean it (use brake cleaner)
- park the car on a level surface in the evening before
- remove dipstick and place a towel onto the dispstick tube to protect it from dust
- place something appropriate onto your steering wheel to serve as a reminder or just leave hood open since no dipstick
- clean dipstick and check oil the next morning, ideally read it in direct sunlight
- your very first attempt will be the best (but only this first one will be necessary anyway)
I can guarantee you this will yield to a clear result.
There is no further modification to the dipstick required, no expensive dipsticks, no magic at all. Realize what's the
cause for the issue, then you'll easily get to the solution. It's the dipstick tube smearing your dipstick and the finish
of the dipstick. Only a matte finish will give a good contrast to the shiny oil. If both are shiny it'll inevitably be hard to
read. The oil will just slowly drain from the dipstick tube. That's why you want it to sit over night. Waiting a couple of
hours while you're on the job will likely serve the same purpose if there's a level surface. Give it a try it at least once.
My spouse's Countryman (same engine, 2014 model year) has about 65k on it and takes a quart top-up every two or three thousand miles. I change the oil no more than every 6k, and aim for 5k intervals. That's kind of frequent for a modern engine but it seems like the engine warrants it. The oil always comes out nearly black.
Jesus, that’s a lot above for just checking oil. Seriously all you need to do is pull the dipstick out and wipe it off, put it back in and give it a spin or two. Pull out and bam easy reading. Takes me less than a minute to check my oil so I check it anytime I let her sit for a few days.
I do it once a month. This minute is well spent.
Pls and thx
i also modified mine a bit, with a fret saw, made 3 small indentations between max and min levels. Now, oil sticks in those marks.
