R56 a softer clutch
a softer clutch
Since day one of purchase of the beloved R56S the stiffness and hardness to press the clutch pedal was always strange. After the passing of the years, its beginning to become a thing to take in mind of and wish that it could be softer. So i had to ask here if anyone has ever though of this, and if there is a way to make it softer.
930 Engineering (10-09-2021)
What you're talking about is the springs in the pressure plate. As a clutch wears, the engagement point in pedal travel moves close and closer to the floor. Pedal effort also increases. You may not notice this change over time because it is so slight, but it will be very noticeable when you install a new clutch disc, pressure plate, and in the case of the R56, a new flywheel (dual or single mass). The clutch pedal effort is much higher on my VW Corrado with a relatively new OE clutch and pressure plate.
930 Engineering (10-20-2021)
![](https://www.northamericanmotoring.com/forums/signaturepics/sigpic130940_6.gif)
They merged the parts. Yes. The older clutches produced before that date had a harder clutch plate.
Should be Valeo on the friction disc and it will have the genuine MINI marking. On that part it will have the original part number or the last 7 of it.
The following 2 users liked this post by njaremka:
930 Engineering (10-20-2021),
ECSTuning (10-13-2021)
This also does not apply to the R56. Mini uses a "self-adjusting" clutch to prevent that change in pedal stroke. The slave cylinder is internally sprung, so it is always engaged with the release lever. This also causes the throw-out bearing to always be engaged with the pressure plate springs. And, the pressure plate has a self adjusting ratchet, so the clearance is consistent. The only way pedal travel will change is if something bends or breaks in the system, which is not unheard of.
Since the clutch has been replaced with an original part by a technician, is it needed to determine if the bellhousing bolts have ever been removed or not?
iDriveR56
05-04-2021 07:15 PM
MiniJayhawk
11-01-2007 11:57 AM
birdmanf16
03-16-2007 09:04 PM
