R56 Timing Chain tension tester
Hi guys I have ordered a Timing Chain tension tester to check the free play in the timing chain on my N12 1.4 non turbo engine. I can find information for the spec for the N14 and N18 engine, below 68 mm ok, above 68 mm replace the chain, should I use that spec for testing an N12 engine?.................Thanks in advance, I would be lost without this forum [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
Here's a link to the related BMW service bulletin --- https://web.archive.org/web/20200706...81_minidoc.pdf Yes, it's written for N14 and no mention of the N12, but note the referenced cause of the problem is the tensioner, not the chain. Based on this info, I suggest you look up the various differences between the two versions (N12 and N14) of tensioner, chain, and guides --- https://www.realoem.com/bmw/enUS/select If both engines use the same tensioner then I'd use the same measurement. I'd be more confident if the chain and guides were also the same, but they probably aren't.
Regardless of part numbers, if your chain has more than about 50K miles, I'd consider changing it anyhow --- more as a precaution rather than a necessity. Maybe wait 'til "you're in there" for something else, instead of doing it ASAP. And FYI --- my N14 chain free play, when new measured 2 20/64" or between 58 and 59mm. 2 43/64" is just under 68mm
Hope this info helps ---
A german shop offers this tool to measure timing chain wear:
https://www.xxl-automotive.de/spezia...ette-fuer-mini
The measurement principle is the same. The tool is suitable for (amongst others) N12, N14, N16 and N18 engines. However, the supplied washer is only to be used with the N14 engine (of those listed here).
I have the tool here, the width of the washer is 4.15mm. Hence, the threshold for the N12 (as well as N16 and N18) is 63.85mm (instead of 68mm).
0.6 nm is the metric equivalent of “finger tight”
Based on the information provided by @oldbrokenwind your chain sounds like it’s in great shape. If your tensioner is still in one piece, just reinstall and be on your way.
Here's a BMW procedure on replacing your timing chain --- https://bmwrepairguide.com/mini-r56-...er-n12-engine/ Check their home page for several more commonly used procedures.
Hi guys one last question, and I do appreciate all the advice you have given. I ordered a timing chain set that is supposed to contain everything......and I have found it does not include a new crankshaft sprocket or bolt.....And I am having a real problem finding them separately, can I get away with using the original sprocket and bolt?.....Hope so!
