R56 Gauges
I believe Autometer makes great gauges. I run an ES series mechanical boost gauge, and the reddish orange backlight matches the OEM orange pretty good, too.
However, the biggest issue I have with aftermarket gauges is where to mount them, and the Autometer gauges have a relatively deep mounting depth. Prosport gauges are slightly thinner, but I’m not sold on their quality….
Since you are looking at 3 different gauges, have you considered adding a Scangauge? It plugs into the OBD port and displays almost anything you’d want to see.
https://www.scangauge.com
I added oil pressure, water temp, and vac/boost. Marshall. Here's what I found. Wiring is back-breaking. Oil pressure worked well, water temp and vac/boost were a pain in the ***:
1) Water temp needed to be sensored in the heater inlet hose to work. If sensored in the radiator hose it would only read temp if the water was too hot. Otherwise no temp at all.
2) Vac/boost. Vacuum works but boost is inaccurate. 10 lbs max on the gauge and much higher reading on the scan gauge. Can't figure this out and Marshall won't return my calls. The wiring was a bit confusing and difficult to hide.
Tip - bring all wiring through the port on the dirvers side. Remove front seats to work under the dash.
That's all I can contribute
Gauges installed.
Gauges installed.
The following 3 users liked this post by danraabe:
Here's my gauges. Two on the sides are ProSport, boost and coolant temp. On top is a HFS4 WMI gauge --- not an option if using WMI. Wiring and mounting is probably the hardest part, regardless of mfgr. I've had these ProSport gauges in use since about 2011. Only problem was when the coolant temp sensor wore out, causing faulty readings. It's mounted in the radiator inlet hose and monitors temp from cold startup. Both gauges have been verified as accurate by comparing to data logs and real-time monitoring at ODB connector. Choice of sensor mounting is critical for proper gauge operation, choose wisely.
Pic shows electronics on, engine off, and my elevation at 4400'
Gauges installed.
Gauges installed.
Interior/Exterior Oil Pressure / Water Temp Gauges?
MSgtEgress
05-21-2018 08:04 AM
jkc1985
12
02-10-2014 12:01 PM
