R56 2011 Base Fuel Pump
2011 Base Fuel Pump
Hey everyone,
I got the "half engine" light on the dash last night and the car started sputtering a bit. Quick google search is telling me it's the fuel pump. Has anyone dealt with this already? If so, do I need to buy an entire new module or can I just replace the actual pump inside the module with something like an Aeromotive 200 lph pump(see the link)?
https://aeromotiveinc.com/product/200-fuel-pump/
Would you mind sharing more info on e.g. error codes, tests, other symptoms, etc.?
Vanski (07-24-2022)
Assuming that you based your diagnosis on more than just searching for "Half engine light + sputtering" (hopefully only considering MINI R56 specific search results applicable to your engine type):
I'm no technician but I'd think there are more than one possible causes for either sputtering or that engine light.
What I do know is that in at least one case (i.e. my own Mini with an N16 engine), rare, short sputtering may be the case without an error code being thrown, much less an engine light coming on (*).
Of course, one could start replacing parts in the hope that that will resolve an issue. Judging by the complexity of these cars, the variety of possible causes (fuel, ignition, air supply or any combination of these), the number of sensors and last but not least forum users' reports here, going that route is usually not the best way.
I'd start by having a BMW/MINI compatible scanner read out any codes and posting them here, along with a more detailed description of the symptoms (e.g. frequency, duration of the sputtering, ambient/internal conditions, whether it usually/only happens at certain times like after filling up the tank, etc.). There are several very well informed and experienced users here who may be able to help you with their MINI specific insight.
*: I suspect that the saturated/damaged activated charcoal filter element (for petrol fumes) has something to do with it.
Yeah, I wasn't sure what may have caused it to get that dirty but the plug was so loose that I couldn't tell if my socket was actually on the plug. I might just change out that cam cover gasket to be safe and clean it all up. It's been filthy in there since I got the car but I've neglected that part. Changed plugs about 2 years ago.
The car does burn oil, I have to add a quart after about 3500-4000 miles. While I don't think that's the only cause, I wonder if that could be adding to the loss of oil.
MidwayMountaineer
06-27-2022 07:39 AM
