R56 Coding Attributes 25W Xenon Headlights
Just did retrofit of 25W xenon's on MCS 2012 followed @ragingMINI 's post #112 in https://www.northamericanmotoring.co...ml#post3916532
After adding $522 to the FA I did a SG_Codieren to the CAS and FRM to code the new vehicle order information and default the modules. Just doing a FA_Write is not enough. Initially I tried just doing an FA_Write and they headlights would strobe once the car was turned on. I then removed $522 doing an FA_Write to the CAS and FRM, to get them back into the previous state. Then I added $522 back to the FA and did a SG_Codieren to both modules. After this I proceeded to disable auto-leveling and charging PWM_FL_BEI_BIXENON to wert_01
ECSTuning (05-04-2022)
R50/53 Halogen to xenon retrofit
OnsideHAZOR
25
07-20-2024 08:30 AM
