R56 Oil leaking
Oil leaking
Recently I discovered oil leaking fwd left of center as below.
I could just barley get a picture with left side lifted a bit.
I had just changed the oil so I checked to see if oring was in filter t was.
today the oil on the floor was a light colored oil?
the picture below it was obvious the oil was being blown around while driving so not sure, except it is leaking.
Could this be the vacuum pump? Just under 100 K 2009 hatchback.
That looks like the bottom of the transmission and bell housing… there are so many components above that spot that have oil going through them. My gut says possibly oil filter housing, which is right above that spot.
My suggestion would be to clean it really good, let it dry, then keep an eye on it from below next up top to try and find where it’s coming from.
k_h_d
10-18-2008 03:57 PM
