R56 Valve Cover replacement
Codes 300,302,304,1497.very rough idle and running. Plugs are clean (no oil), oil is clean (no water), no visible oil seapage around the vc. 2008 Mini S R56
P1497 is an air leak downstream of the throttle. My guess is the PCV pipe that goes from the cam cover tot he manifold is cracked. They are made from cheap plastic that cracks with age.
https://www.northamericanmotoring.co...916-p1497.html
The other codes are related to mis-fires, which could be a result of the cracked PCV hose. I would replace the hose, clear the codes, and see how she runs.
Parts diagram with part number here:
https://www.realoem.com/bmw/enUS/sho...diagId=11_3915
For purchase:
https://www.ecstuning.com/Search/Sit...h/11157605186/
For purchase:
ECSTuning (05-11-2022)
Bremmen Parts to the rescue!
