R56 Fuel filter leak
Fuel filter leak
car has been smelly for a few months now and I discovered this. I wonder if its leaking from that blue line's connector or if its leaking from the housing and tank gasket? does this kit include what I would need to fix it if its leaking from the blue line connector? https://www.fcpeuro.com/products/min...st-11252754870
thanks.
thanks.
This just has the gaskets. We have the tool linked which helps with the gasket. DIY here https://www.northamericanmotoring.co...r-housing.html and https://www.northamericanmotoring.co...-change-2.html
https://www.ecstuning.com/Search/Sit...h/11252754870/
If its the green connection: https://www.northamericanmotoring.co...el-filter.html
hopefully its not the o-rings in the housing lid, cause those I don't think can be bought. requires buying a whole housing.
If you are messing with it might as well do the filter. I would get the tool also.
GonnaMini
12-27-2020 06:12 PM
