R56 GFB DV+ paired with Alta spring
The Alta spring won’t work with the DV+
The only part you use from the OEM valve is the actuator body:
https://gfb.com.au/download/t9352-in...a0261652957728
Installing/working on mine is pretty straight forward. I remove the intake pipe, move the coolant can out of the way and use a long allen wrench on the dv housing bolts. I hook the closed end of a wrench on the end of the allen wrench to loosen/tighten the dv bolts. Gives me some extra leverage
