R56 No Power Steering
No Power Steering
2007 MCS R56, N14:
After two days of letting it just sit there, I went back out and tried starting the car. It started right up. No more relay clicking like in the video. However, there is now no power steering. I started and stopped the car several times without issue. I've driven down the block and back 5 times and still no power steering. I have the Foxwell NT510 and used that to delete adaptations with no results. I also have no power steering fault codes or icons.
I'm at end of job here and don't even know where to look next. What are your thoughts?
Again, this video is from a couple of days ago and the K6300 port is no longer clicking like this. My only issue now is power steering. I post this video in case it lends itself to an underlying problem that I don't know how to diagnose.
- 80,000 miles
- No leaks
- Son drives it 10-15 miles a day to school and back
- New serpentine belt and water pump 12/3/2021
- New timing chain (and deleted adaptations) 3/19/2022
@wsdivall
Hi,
Looking at my Bentley Publishing service manual, the power steering system is controlled by Electromechanical Power Steering(EPS) control module which is located right on top of the steering rack and it is in tandem with the DME. First check the "SPORT" button right by the shifter. Does it turn on when depressed? Next unplug the wiring harness from the EPS control module and see if there are any corrosions at the terminals. If there is, then you know water condensation is getting into the terminals. Simply clean those corrosions by using contact cleaner and put some di-electric grease to prevent any future corrosions.
Hope this helps
Hi,
Hope this helps
The following 2 users liked this post by Vanski:
930 Engineering (08-20-2022),
wsdivall (05-24-2022)
@wsdivall
Hi,
Hope this helps
Hi,
Hope this helps
Other than unplugging everything, checking fuses/relays, and checking voltage drops, I'm not really sure what ended up fixing the car... which is unfortunate because I fear my car is going to die in the middle of driving it again. I think I can now appreciate the phrase 'gremlin in my mini'.
Thanks for your help.
ve9aa
01-30-2019 08:12 AM
