R56 Recommend an *inner* axle (tripod) joint grease?
Hey guys,
I keep reading that the inner and outer axle joints take different grease because the inner tripod joint has needle bearings and the grease therefore needs to be thinner. The BMW parts for the replacement boot kits aren't specific about what grease they come with.
Both joint boot clamps/straps were loose and spitting grease so I need clean and refill and reclamp. I have Sta-lube CV joint grease but it doesn't mention use in tri-pod joints.
Thanks!
Thanks!
I've read that the needle bearings in the inner tripod joint need NLGI No.1 grease (less viscous), the outer needs No. 2. I read the product sheet for Sta-Lube and it says its NLGI 1.5. Maybe they mean for it to be for both inner and outer?
thanks brother.
I used these pliers to pre-tighten the inner/tripod bellows clamp a little tighter before using the special pliers to permanently clamp it. Which by the way is possible without taking the axle out of the transaxle. The crimper tool just barely fits in there to crimp the clamp.
Lex2008
How to
11
09-07-2017 10:19 AM
flatblackmini
04-26-2012 05:15 AM
