Been lurking here a while. Recently, purchased a 2012 R56 N18. The car over heats. I replaced thermostat (mini) and fan (oe). Still overheating. Fan comes on with scan tool, ac, and unplug temp sensor but does not come on when temp rises. Coolant begins to rise and sizzle out, coolant tank really hot. I did fill coolant with schwab coolant fill tool so should not have air in system. Looking for help suggestions here. Thank you.
You didn’t mention how many miles you have on it? You might want to check the friction wheel that drives the water pump from the crankshaft pulley. The spring loaded tensioner maybe worn out
