R56 Will not move in any gear
I have a 2011 Mini S with the N18 engine and 6-speed auto. I just finished putting a new engine in it this week and went to test drive it this morning and it will not move in any gear. The ATF level is good, the shift linkage is hooked up as it should be, there are no warning lights or codes present, it's not making any noises, it shifts from Park into Drive and Reverse just fine but will not move in either. Any ideas?
I did not drain the torque converter, just swapped it right over to the new motor. When I shift into drive or reverse the rpms drop slightly like any automatic and it feels like the transmission is engaging, so the torque converter has to be working. I think that the transmission is spinning but its not connecting with the transaxle. I don't know if it's chain, belt, or gear driven inside but I think something between the two let go and maybe that's why the motor went, or vice versa. I'm going to get a new transmission this weekend and tear it all apart again.
@Shields Racing
Another possible cause would be the clutch bands. What is the exact condition of those clutch bands?
Automatic transmission clutch band
AnOldBiker
07-28-2018 06:17 PM
chrisneal
02-04-2003 06:23 AM
